21 December, 2024, 05:22:21 PM *
Pages: 1 ... 7 8 9 10 11 [12] 13 14 15 16 17 ... 31   Go Down
Author Topic: my new integrale  (Read 193085 times)
0 Members and 19 Guests are viewing this topic.
Kevinlincs
« Reply #165 on: 22 July, 2018, 10:03:13 PM »
The side of the tower showed signs that it too craved attention....
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #166 on: 22 July, 2018, 10:04:59 PM »
No prettier from under the arch..the grot had spread quite a way up the hollow parts of the reinforcing section
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #167 on: 22 July, 2018, 10:06:29 PM »
No point being shy, out with the lot!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #168 on: 22 July, 2018, 10:09:06 PM »
In stead of recreating the double skinned scenario where you actively promote corrosion I made a new repair piece out of single skin but as thick as the 2 pices, the ribs took an age to from in them!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #169 on: 22 July, 2018, 10:10:44 PM »
Strong again
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #170 on: 22 July, 2018, 10:12:38 PM »
The chassis side under the bottom reinforcer wasn't up to much either..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #171 on: 22 July, 2018, 10:14:23 PM »
All boxed in with more of the thick steel
That's it for now.....I'll carry on again soon with the updates
Flavia 815 coupe
Delta integrale
lancianut666
Slow but rough
« Reply #172 on: 23 July, 2018, 08:30:40 AM »
I love your cutting out of the rust no messing!!!
Clarkey
« Reply #173 on: 23 July, 2018, 06:37:59 PM »
I'm wondering what you used to create the reinforcing ribs?
Kevinlincs
« Reply #174 on: 23 July, 2018, 09:00:37 PM »
Clarkey
Only way to me mate!
I always preach to anyone that will listen, welding a plate is the same if it's 4" square or 4' square. May as well get rid of the lot whilst the grinder is at hand.
Will say though that it's not as scary to do now as it was at first, you sometimes feel there's no car left!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #175 on: 23 July, 2018, 09:04:58 PM »
A tool similar to this, called a bead roller or sometimes a Jenny Wheel
Handy tool for rolling the curved wheel arch sections too.
https://www.ebay.co.uk/itm/19-BENCH-SWAGER-ROTARY-METAL-TOOL-JENNY-BEAD-ROLLER-outil-Werkzeug/253769471478?hash=item3b15d6d5f6%3Ag%3A4gsAAOxygPtS37Mw&_sacat=0&_nkw=bead+roller&_from=R40&rt=nc&_trksid=p2380057.m570.l1311.R1.TR6.TRC2.A0.H0.Xbead+roller.TRS0
Flavia 815 coupe
Delta integrale
« Reply #176 on: 24 July, 2018, 11:04:30 AM »
That looks like it might be worth investing in. Did you have to press the swages in stages or was it one continuous slow roll?
Kevinlincs
« Reply #177 on: 24 July, 2018, 06:18:28 PM »
On thinner more regular stuff like 1mm or even 1.2mm steel you can do it in one pass.
This steel was about 2.5mm thick so it had to be done in a few runs, nearly more than the tool could handle in reality, hence the wobbly lines!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #178 on: 10 August, 2018, 09:32:20 PM »
The drivers side strut tower and inner wheel arch was much the same process as the other side so I won't go through all that again.
One job that I had been putting off for some time was to clean the underside of the years and years of underseal and mess that had gathered there, not a nice job.
The black underseal was scraped off using a heat gun and a wallpaper scraper, best combination I find for that job. Messy and hot, but best.
Once all that was cleaned off then we were down to the factory rubberised stuff that I use a knotted wheel on an angle grinder to take off, this flings it about a bit but cleans it efficiently and also if there are any rust spots under it then it cleans that too, just be careful not to have exposed skin as the little needles off the knotted wheel easily stick in your cheek! A full face mask is a must, not just goggles.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #179 on: 10 August, 2018, 09:34:50 PM »
After a few hours and a bucket full of rubber crumb you end up with a fairly clean surface...
Flavia 815 coupe
Delta integrale
Pages: 1 ... 7 8 9 10 11 [12] 13 14 15 16 17 ... 31   Go Up
Page created in 0.054 seconds with 21 queries.
