26 December, 2024, 01:10:46 PM *
Author Topic: Oil Pressure Sender variants  (Read 3053 times)
Angle Grinder
« on: 28 October, 2015, 08:39:09 PM »
Whilst changing my oil I decided to remove my Veglia oil pressure sender to see if it had any part number markings on it to help me source a replacement.
There weren't any markings that looked like a part number, but around the oil inlet side there were some marking as follows (they might be visible in the pics): 09.01 / 0 - 8 / 3N
I assume that the 0 - 8 is an indication of the calibrated range of the sender so it will measure from 0 to 8 bar.  Does that sound correct for a Flavia 1800?
The sender doesn't look like it is an OEM part, but I've nothing to verify it against.
« Last Edit: 28 October, 2015, 09:16:12 PM by Angle Grinder » Logged
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
Brian Long
« Reply #1 on: 09 November, 2015, 12:16:04 AM »
My Flavia2000 oil pressure gauge has a range of 0 to 70 (psi). The needle never used to get much above halfway and was unsteady. The sender was stamped 0 - 7.
I got a new sender from Omicron which was stamped 0 - 6. When installed the pointer shows just short of an indicated 70 psi once above an idle.
Hence, the actual pressure being sensed is 70 X 6/7 = 60 psi which I think is pretty healthy.
Angle Grinder
« Reply #2 on: 20 November, 2015, 02:55:30 PM »
Thanks for the info Brian. I haven't tried Omicron yet, but to date I've only been able to find Veglia oil pressure senders in the 0 - 8 bar range. I should really stick a meter on the engine to get a true reading, but it seems a bit daft to buy a meter to test the oil pressure when a new pressure sender might fix the problem and only cost a few £'s more.
Previous cars:
1983 Prisma 1600
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
