10 January, 2025, 03:47:07 PM *
Author Topic: Nuts !  (Read 4213 times)
« on: 02 November, 2015, 05:24:02 PM »
How do I go about undoing the bearing carrier on the Appia back axle without damaging it ?
I suspect that there was a special tool "chez Lancia" . The size across the flats is 98mm
Any suggestions ?
« Reply #1 on: 02 November, 2015, 06:14:17 PM »
Any suggestions ?
Chain Wrench?
« Reply #2 on: 02 November, 2015, 06:23:03 PM »
Have you asked Don Cross. Maybe something in the Appia Consortium?
« Reply #3 on: 03 November, 2015, 02:03:31 PM »
Is there a "special tool book" for the Appia on one of the CDs?
« Reply #4 on: 03 November, 2015, 04:47:04 PM »
Unfortunately standard Appia is about 78 mm not 98 as on the van,  apparently the nut is v tight so the chain wrench is unlikely to work, but always worth a try !
I think that I will have to try making a tool, anyone any experience of cutting steel to make a spanner ?
« Reply #5 on: 03 November, 2015, 05:17:12 PM »
Normally spanners are forged to get their strength. May be machine from 100mm tool steel bar to keep the tube and strength.
« Reply #6 on: 03 November, 2015, 06:04:30 PM »
Is that just two flats there Simon, I am not sure quite what I am meant to be looking at?
We have successfully made spanners from 6 or 8mm flat. Cut out the two faces at 98mm, keep it as a closed item ie cut a square out of the flat, rather than open ended. The other (easier) way to achieve this, is to cut it as an open ended spanner, but then weld a piece across the open end to give it that extra strength.
« Reply #7 on: 03 November, 2015, 06:13:06 PM »
Another thought, we have done this as well, is to use a piece of suitably sized piece of square or rectangular hollow section. Cut, say a 100mm length, weld a 'cheek' in to produce the required 98mm across the flats and either weld a bar across the end or onto one side to act as the lever or drill holes in opposite faces through which to pass a bar as the lever.
Good luck however you choose to attack this!!!!
RobD
« Reply #8 on: 04 November, 2015, 01:57:56 PM »
Whatever you do, try and introduce plenty of heat. Heat is a very undervalued tool in the workshop and can save a lot of heartache. Also try to ascertain whether it's LH or RH thread!
Apologies if I'm teaching my granny to suck eggs...
'75 Fulvia 1.3S
'68 works Laverda 125cc ISDT
KTM 640 Adventure
Yamaha TDM 900
www.adventureride.co.uk
