08 January, 2025, 08:19:47 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Buy, Sell and Search
Spares required
Wanted: S1 Fulvia coupe starter motor
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Wanted: S1 Fulvia coupe starter motor (Read 10423 times)
Andrew1950
Re: Wanted: S1 Fulvia coupe starter motor
Reply #15 on:
24 December, 2015, 01:56:32 PM »
Just took off the starter and it's also a Bosch 0001 115500. Stuck cables on it and again, the pinon gear shoots out.
Andrew1950
Reply #16 on:
24 December, 2015, 02:00:03 PM »
As you can see there is a little damage on the upper part of the pinon gear where is says 907. When I turn the pinon gear it's quite free (loose with no tension)
Any suggestions?
ben
Reply #17 on:
25 December, 2015, 02:29:39 PM »
You describe the pinion as shooting out when you test the starter away from the engine which is what it should do of course but you don't mention whether the motor also responds by vigorously spinning.
It is quite a common problem that the solenoid pulls the pinion into engagement but the heavy duty contacts in the end of the solenoid fail to make a good enough connection to power up the motor properly.
I cannot tell from your photo's if the solenoid is the type that can be dismantled but if it is it may respond to having the switch contacts cleaned. This will probably mean you have to unsolder the wire on the end of the casing to allow it to be pulled apart.
On the other hand if the motor does run as it should but the pinion is failing to engage the ring gear I would suggest you take some measurements to see if the gears are in the correct allignment when the pinion is in its fully "thrown" position before you randomly start removing the spacing washers.
If everything does seem to be correct you are left with the most likely problem as one of insufficient electrical power reaching the motor due to a poor connection elsewhere. After an extended period of trying to operate the starter (in the whirring mode) if there is a poor connection it will probably get warm--or even hot--so feel all the connection points from both battery terminals onwards to try to find which one it is.
Good Luck
Pages:
1
2
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
Model Technical and Interest
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
