Hi again any advice appreciated.
The dip main switch works but is very sensitive. Often when going over a bump it will go from full beam to dip.
Has anyone else encountered this problem?
Will it involve new parts and can they still be obtained?
Many thanks Mike
Mike.
Are you talking series one Fulvia? if so the springs in the switch are weak, unless you can tighten them up I think you'll need another switch, I had to do so to cure the problem on my 2c.
If you need one I can probably help.
8227
