27 November, 2024, 07:54:28 AM *
Pages: 1 [2]   Go Down
Author Topic: Engine oil for Fulvia 1.3  (Read 12502 times)
ColinMarr
« Reply #15 on: 04 June, 2016, 08:30:22 AM »
I thought we had been here before on this forum. I googled HPX and found all of this from 2008 - amazing!
Model Technical and Interest => Fulvia => Topic started by: ian on 09 April, 2008, 10:39:36 PM
Title: fulvia fluids
Post by: ian on 09 April, 2008, 10:39:36 PM
hi all!
s3 1.3 coupe needs a full service, any recommendations on engine and gear oils, air and oil filters etc. types, makes and suppliers?
any advice gratefully received Smiley
Title: Re: fulvia fluids
Post by: lancialulu on 09 April, 2008, 10:52:34 PM
I use duckhams classic 20/50 in 1.3 assuming it has done a few miles. Mobil 1 synthetic 75/90 for gear box, get filters from omicron.
Post by: stuwilson128 on 10 April, 2008, 08:40:56 PM
For the oil filter, I usually go to my local motor factors with the following list of filters.  They normally have at least one of them.
FRAM PH2803-2
MANN W940/25
FRAM PH3569
BOSCH P 4065
Post by: YKR 567J on 11 April, 2008, 05:53:56 PM
Yes, the oil filter is the same as used on an FX-4 taxi and several Japanese cars, I think.
John Simister
Post by: ian on 11 April, 2008, 08:47:56 PM
thanks for all the feed back, she,s done 70,000 plus been around the clock! not the original engine though!
do the air filters share with any other marque? and are they usually available from local motor factors as well?
Post by: ColinMarr on 13 April, 2008, 07:47:33 PM
For my Fulvia 1600 I use Selenia HPX oil, which Fiat recommends for high performance engines that have already done considerable mileage. It is rated 20/60 and is I believe called ‘semi-synthetic’, whatever that means. I buy it from my local Fiat agent and it costs about £20 plus for 5 litres. My engine has done about 80,000 miles and it consumes about 0.5 litres of oil in 700 miles, which is I think about what you expect from a 1600.
I change the oil filter every 3000 miles, with the oil change. The last oil filter I used was a FRAMM FT 4403. The packaging shows cross references with Toyota: 15601-96101, MANN: W 940/1 and Tecnocar: R 65. Under main applications it lists – Toyota Land Cruiser and Range Rover F.3.5 V8.
For the air filter, I tend to change this less frequently and simply clean it out and reuse it until it looks grotty. I would be interested to know if others do the same.
Colin
Post by: Peter W on 14 April, 2008, 08:12:10 PM
I also use HPX on both my Fulvia 1600 & my Beta VX.  It is a synthetic oil and although it was rated at 20W/60, the latest cans say 20W/50.  Have used it for 10 years with no problems.  I change my air filter after about 4000 miles as I find it gets a little oily from the crankcase breather which I suspect restricts its breathing properties.  Might just be my imagination though.
Post by: ian on 14 April, 2008, 08:47:04 PM
yes, my brother-in-law used to compete in the fiat lubrificante challenge a few years back and used it in his uno...and i use  to pinch a bit for my 128. the crankcase breather on the 128 used to chuck a bit of oil back to the filter, but not on the fulvia, even though she  gets driven much harder Wink
but as for oil use in the 1300 fulvia ....it doesn't use any? is that unusual?
Post by: nistri on 18 April, 2008, 01:53:43 PM
Fulvia air filters: it seems that the Tecnocar production of these has stopped and I don't know how long currents stocks will last. Not so easy to get replacements, unfortunately. No foreseeable difficulties for oil filters.
If there is engine oil inside  the air filter box or on the air filter, piston rings are probably worn.
Andrea
Post by: St Volumex on 29 April, 2008, 07:39:08 AM
We started using SAE 40 Super Monograde oil in the engine on the recommendation of a past Chairman of the SA club, and notice that older Fulvias smoke less when using it.  Cheesy
For the gearbox we use Shell Spirax SAE 80W-90 - same as for the VX supercharger.
We still managed to buy a Technocar A-818 R filter last year, but maybe these are old stock?
In the meantime somebody down here has made a reusable (washable) filter in the same vein as that on the Flavia.  Cost w/out shipping is about £25.
Pic to follow.
Kindest regards,
Post by: ian on 17 May, 2008, 05:55:59 PM
Visited a couple of local motor factors today, I can get hold of oil filters, no problem.
1st one available, Fram part no.FRA PH8A, description Z877, £4.99
2nd one, WIX 7068, about £6-7
No air filters available at all. I have unfortunately thrown away the old one as it was swimming with brake fluid (see s3 master cylinder postings) can anyone take some O/D, I/D and height  measurements etc for me. or does any one have any other ideas?
Post by: fay66 on 18 May, 2008, 08:37:10 AM
Have a look on ebay, some for sale on there recently.
Item number  360053274339 on ebay Italy is for an air cleaner filter, set of plugs, condenser & points, current bid is £55.
Post by: ian on 16 July, 2008, 10:53:51 PM
In the end Omicron supplied it all for me, (apart from the fluids) at a reasonable cost I think  Grin
Post by: davidwheeler on 17 July, 2008, 01:05:13 PM
I use 10/40 synthetic from LSUK in my second series.  And in my Lambdas for that matter.  Works fine and does not cost the earth.
Post by: Scarpia on 17 July, 2008, 04:46:08 PM
Do you see evidence of increased oil leaks/seepage or get a mist of oil over the engine bay with the synthetic in the Lambda?
Post by: Peter Gerrish on 23 July, 2008, 09:02:47 AM
I have been using Valvoline Racing 20W/50 in Fulvias (and Lambdas once fitted with modern oil filter cartridge) with good results. At one stage I raced my 1600 Sport on it with no problems. If your engine uses oil in large quantities, any cheap 20W /50 will do!
I agree with Colin Marr, air filters can be blown out with airline unless they start to look discoloured or oily. I still have  about 10 air filters in stock.
Plus as you can see ,I have at last joined you "moderns" on line. Cheers. Peter Gerrish.
Post by: fay66 on 23 July, 2008, 09:27:37 AM
Nice to have your expertise available Peter, Welcome
Post by: YKR 567J on 23 July, 2008, 10:05:24 PM
Yes, Valvoline Racing 20W/50 seems fine in my Fulvia, which uses very little of it. That could well be because Peter made such a fine job of building its engine... welcome to Lancia cyberspace, Peter!
John
PS Valvoline synthetic 75W/90 gear oil, compatible with GL3 (old), GL4 and GL5 (modern) specs works very nicely in the gearbox, making the shift lighter and smoother especially when cold.
Post by: Scarpia on 24 July, 2008, 04:11:15 PM
Most of us are approaching an age where being described as "moderns"  can be taken as a compliment....thanks Peter  Wink
Suddenly , life doesn't seem so bad after all...
and yes....just to add to the list, Mr Gerrish rebuilt our 1.3 engine also and its still going strong after 15 years.... A warm welcome Peter.
« Reply #16 on: 14 June, 2016, 08:49:05 PM »
To close this one, a variety of oils are used - synthetic, mineral, semi-synthetic, thin, thick - all personal preference and no one has destroyed an engine due to a pre-defined preference so ........
Thanks for everyone's input
Caracad
« Reply #17 on: 19 June, 2016, 06:22:42 PM »
Mobil 1 10-60.
Not to thick and sticky when cold and then keeps it viscosity even when really hot. Hence 10-60.
If lancia had oils like that back in the 60s70s, that's what they would specify.
As for clearances and tolerances, I reckon a Fulvia engine is as tightly put together as anything modern.
« Reply #18 on: 20 June, 2016, 12:53:24 PM »
Oil is as much a coolant as a lubricant so high oil pressure is not necessarily a good thing if it is achieved by thick oil - old Used Car Salesman's trick - put gear oil in a knackered engine, looks marvellous and lasts long enough to get rid of the poor sucker before the big ends go.    10-40 semi synthetic does mine very well indeed and is thin enough to provide high flow through the bearings.
Pages: 1 [2]   Go Up
