21 December, 2024, 01:18:18 PM *
Pages: 1 ... 4 5 6 7 8 [9] 10 11 12   Go Down
Author Topic: My Delta HF turbo ie Restoration  (Read 92498 times)
Rob
« Reply #120 on: 30 August, 2018, 07:59:52 PM »
It was all going so well.... I was trying to push the pistons out of the front brake calipers by removing one of the brake pads & applying pressure to the brake pedal but they didn't want to budge. Finally the pedal started to move which got my hopes up but when I checked, the pistons were still in the same position  Huh? When I looked towards the rear of the Delta there was a pool of brake fluid, one of the pipes had split  Cry. Unfortunately it had been leaking for a little while before it finally split as the paint had lifted on the bottom half of the rear crossmember  Roll Eyes. So today I removed the rear crossmember & I'll be looking at getting it powder coated also I've ordered some new front brake calipers as the old ones are seized solid!
                       Cheers, Rob
Rob MacFarlane
1988 Delta HF turbo ie
2000 Fiat Coupe 20v
1987 VW T25 Camper
« Reply #121 on: 30 August, 2018, 09:24:10 PM »
On the bright side you can remove the rear cross member quite easily!
« Reply #122 on: 31 August, 2018, 09:54:49 AM »
Anything else to look at while its apart?
Rob
« Reply #123 on: 31 August, 2018, 10:01:52 PM »
Yes it was fairly straight forward to remove the cross member although I had to cut through the brake pipes that go into the brake balance compensator as the compression nuts had rusted solid. I'm going to replace the brake balance compensator as it's looking pretty tired. Also the plastic connecter that fits in-between the transverse links has broken so I'll have to make a new one. As the cross member is off the car I'm going to get it stripped, galvanised & painted  Wink.
« Last Edit: 29 May, 2019, 10:50:21 PM by Rob » Logged
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
« Reply #124 on: 31 August, 2018, 10:58:16 PM »
I'd have hoped Lancia would have used something better than plastic to make that connector from Roll Eyes
Keep up the good work Rob, will she be ready in time for Castle Coombe?.
Rob
« Reply #125 on: 01 September, 2018, 06:05:37 PM »
I'm guessing the reason it's plastic is because it's designed to break. Either that or FIAT were keeping the costs down (more likely). It's not looking good for Castle Combe now as the to do list is getting longer again  Undecided.
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
ben
« Reply #126 on: 09 September, 2018, 10:52:28 AM »
Hi Rob
If you have an entry for Castle Combe you could take my 8V along if your car is not ready.
Just check that to make it legal your regular insurance covers you for driving other peoples cars---they usually do.
Ben
GialloHPEIan
« Reply #127 on: 09 September, 2018, 12:47:34 PM »
Hi Rob
That plastic part would be an ideal candidate for 3D printing I would think.
Good to know that you have a back-up vehicle if you don't complete the work ready for the Autumn Classic event, thanks to Bens kind offer. Smiley
Regards
Ian (6610)
1998 Delta HPE 2.0HF Turbo 16v
1968 Land Rover Series IIa Lightweight
2018 Fiat Ducato L2H2
2011 BMW 1 Series 118i M-Sport Convertible
Prev.Lancias: Beta Spyder 2000('80) Delta HF Turbo Martini('88) Prisma 1600('86) Montecarlo('77) Dedra Turbo(
Rob
« Reply #128 on: 10 September, 2018, 09:14:43 PM »
Hi Rob
Ben
That's very kind of you Ben  Wink. Unfortunately my insurance wouldn't cover me as your integrale is in a higher category than my Alfa 147 but thanks for the offer. Fellow Bristol member Steve is giving me a lift in his Evo so I'll be going in style  Cool. It's times like these that you realise what a great bunch of blokes we have in the Bristol / Frome area, Viva Lancia!
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #129 on: 10 September, 2018, 09:20:57 PM »
Hi Rob
Regards
Ian (6610)
I had a look to see how much Shapeways would charge to 3D print it & to print a one off they wanted £1200  Roll Eyes. So I've bought a block of nylon off eBay for £9 & I'll shape my own using a Hacksaw, files & drills. Keeping it old school (& cheap!)
Cheers, Rob
« Last Edit: 10 September, 2018, 09:24:05 PM by Rob » Logged
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
« Reply #130 on: 11 September, 2018, 01:43:49 PM »
Hi Rob
Regards
Ian (6610)
Cheers, Rob
Quite a lot of small Delta parts in the mechanical parts section, including a brake balance arm still quite expensive at £40 but nicely made.
and if you're that way inclined the exterior door handle pull with the Delta HF Logo embossed, ready to paint.
Rob
« Reply #131 on: 12 October, 2018, 03:04:01 PM »
Progress has been pretty slow recently but at least there's been some  Wink. The cross member has been stripped & painted & I've bought new front & rear brake calipers & a new brake balance regulator which altogether came to £600  Roll Eyes. Christmas has come early for the Delta!
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #132 on: 12 October, 2018, 03:41:41 PM »
Here's the tie rod connector I made from nylon. It took a fair few hours to carve out but I was quite chuffed with it!
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
« Reply #133 on: 12 October, 2018, 03:46:15 PM »
All looks very nice. How did you carve the nylon and make the holes?
Rob
« Reply #134 on: 12 October, 2018, 03:55:43 PM »
I used a pillar drill for the holes, a bandsaw to cut out the shape & sandpaper to take off the rough edges. Not a 3D printer in sight!  Wink
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Pages: 1 ... 4 5 6 7 8 [9] 10 11 12   Go Up
