Rob
« Reply #45 on: 26 April, 2017, 05:55:32 PM » |
Then some filler to help the repairs blend in.
Rob MacFarlane
1988 Delta HF turbo ie 2000 Fiat Coupe 20v 1987 VW T25 Camper
« Reply #46 on: 26 April, 2017, 08:12:44 PM » |
Commiserations on the hand. At least you didn't torch the car and the house. I keep a few old washing-up liquid squeeze bottles filled with water handy when welding. You can direct a concentrated jet of water on any little accidents including into tight spaces.
« Reply #47 on: 27 April, 2017, 11:07:11 AM » |
Am working on a welding trolley design at the moment. It will have a little fire extinguisher and a blanket on board but "water pistol" is a great idea.
« Reply #48 on: 27 April, 2017, 11:07:45 AM » |
Any favorite brands of paint, filler, paper?
Rob
« Reply #49 on: 27 April, 2017, 10:00:06 PM » |
I use Isopon P38 easy sand filler & Isopon 182 zinc primer. I then use Carplan high build primer & for the top coat I use Fiat racing red from a spray / rattle can (which is a pretty good match). On areas where it needs a bit of extra protection (and are not visable) I use Hammerite bush on paint. Ideally I would like to get the bodywork resprayed professionally but my main aim is to get the shell & body panels completely rust free & all the oily bits mechanically sorted  .
« Last Edit: 27 April, 2017, 10:13:41 PM by Rob »
Rob MacFarlane
Rob
« Reply #50 on: 08 May, 2017, 07:24:02 PM » |
And now for the top coat of paint  . Still loads to do but it feels like I'm getting there, slowly but surely  .
Rob MacFarlane
Rob
« Reply #51 on: 08 May, 2017, 08:01:36 PM » |
Next job was the tailgate. The original was so badly corroded that I pretty much folded it up & put it in the bin. The replacement was almost factory fresh by comparison & just needed attention to 4 small areas as shown in these pics.
« Last Edit: 08 May, 2017, 08:13:00 PM by Rob »
Rob MacFarlane
Rob
« Reply #52 on: 08 May, 2017, 08:18:23 PM » |
A bit more welding.
« Last Edit: 08 May, 2017, 08:22:46 PM by Rob »
Rob MacFarlane
Rob
« Reply #53 on: 08 May, 2017, 08:28:01 PM » |
All cleaned up, painted & looking much better  .
Rob MacFarlane
« Reply #54 on: 08 May, 2017, 09:02:06 PM » |
you don't show the patches seam welded. Do you just spot weld then fill and paint or is seam welding taken as read?
Rob
« Reply #55 on: 12 May, 2017, 06:40:00 PM » |
All the structural areas have been seam welded but repairs to body panels are spot welded which keeps the distortion to a minimum.
Rob MacFarlane
« Reply #56 on: 12 May, 2017, 07:50:23 PM » |
Thanks. That's useful to know.
Rob
« Reply #57 on: 09 July, 2017, 09:48:43 PM » |
I went to the LMC AGM today as it's been about 6 or 7 years since the last time I attended & had a most enjoyable afternoon  . Had a good chat with Rich Carr then had a good look round at all the Lancias with Ben. Weather was hot & sunny which always helps  . Got chatting to a fellow Delta fan Andy who has a HF turbo, Prisma & 1.3 LX (lucky fella!). Also had a little catch up with Brian Hinton & his 3 dogs. I was impressed with the quality of the cars on show but it did feel like the quantity was down since I last attended. It was great to see 2 stratos' though with one being a works safari & the other an exellent replica. My favourite Lancia of the day was a cracking Delta HF 4wd  . You don't see these models very often & this one was in amazing condition. The owner had owned it from new then sold it after 3 years, he regretted selling so much that his wife bought it (when she saw it for sale in a local garage) & gave to him as a present on his birthday! What a wife!
Rob MacFarlane
Rob
« Reply #58 on: 01 September, 2017, 07:50:43 PM » |
Here's a repair that I've done on the rear drivers side door a little while ago. It doesn't look to bad but still took quite a bit of time to make the repair inner & outer sections. Once I was happy with the shape it was time to get the MIG welder out.
« Last Edit: 01 September, 2017, 07:58:38 PM by Rob »
Rob MacFarlane
Rob
« Reply #59 on: 01 September, 2017, 07:53:45 PM » |
And a bit of filler & paint to finish.
« Last Edit: 01 September, 2017, 07:59:31 PM by Rob »
Rob MacFarlane
