21 December, 2024, 12:23:27 PM *
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12   Go Down
Author Topic: My Delta HF turbo ie Restoration  (Read 92487 times)
Rob
« Reply #75 on: 25 November, 2017, 07:52:52 PM »
Thanks Kev, your words of encouragement are much appreciated  Cheesy. Here's a of pic of the same area after I'd ground out all the rust & prepped it ready for welding.
« Last Edit: 06 December, 2017, 09:10:27 PM by Rob » Logged
Rob MacFarlane
1988 Delta HF turbo ie
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #76 on: 06 December, 2017, 09:04:54 PM »
After making the repair section out of some good quality mild steel, I tacked it in position then fully welded it  Wink.
« Last Edit: 06 December, 2017, 09:11:40 PM by Rob » Logged
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #77 on: 27 December, 2017, 03:51:17 PM »
After a coat of zinc primer, some seam sealer & a couple of coats of Hammerite's finest red gloss, it's looking pretty good  Grin. Hope you're all enjoying the Christmas hols & hope you have a happy new year!  Cheesy
« Last Edit: 30 December, 2017, 03:38:02 PM by Rob » Logged
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
« Reply #78 on: 27 December, 2017, 10:18:57 PM »
Festive colour.  Keep at it !!!
Rob
« Reply #79 on: 29 December, 2017, 04:31:08 PM »
Thanks David. Yes it's certainly a festive colour  Wink. I spotted this Delta HF turbo ie 1/18 scale model on ebay yesterday & ordered one to add to my collection.
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #80 on: 30 December, 2017, 03:42:26 PM »
Here's a photo of the new near side front shock absorber that I put together today & a photo of the old one which was well past it's prime!
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
GialloHPEIan
« Reply #81 on: 30 December, 2017, 06:42:28 PM »
Hi Rob
You're making great progress. The diecast you've treated yourself to will help keep you motivated i'm sure. I see that you can get the same model in Martini UK spec i.e. RHD.
https://www.ebay.co.uk/itm/Lancia-Delta-1600-Hf-Turbo-IE-Martini-3-Serie-Uk-1986-LAUDORACING-1-18-LM108EN/132441181087?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D17d33f369a5f48d5b3f0b642a79941be%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D132441181087&_trksid=p2481888.c100675.m4236&_trkparms=pageci%253Afbbcb0ab-ed90-11e7-8717-74dbd180695e%257Cparentrq%253Aa8ba2b0f1600aa12a9460f0effe450e6%257Ciid%253A1
Happy New Year.
Regards
Ian
1998 Delta HPE 2.0HF Turbo 16v
1968 Land Rover Series IIa Lightweight
2018 Fiat Ducato L2H2
2011 BMW 1 Series 118i M-Sport Convertible
Prev.Lancias: Beta Spyder 2000('80) Delta HF Turbo Martini('88) Prisma 1600('86) Montecarlo('77) Dedra Turbo(
Rob
« Reply #82 on: 30 December, 2017, 11:12:44 PM »
Hi Ian,
Yes I was chuffed to find this model as usually you can only get integrals in the 1/18 scale. I'm feeling really motivated on the Delta restoration lately, I usually stop working on him as we go into winter but this year I've braved the cold weather & managed to keep going  Smiley.
Cheers, Rob
« Last Edit: 30 December, 2017, 11:28:21 PM by Rob » Logged
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #83 on: 04 January, 2018, 10:03:04 PM »
Here we see the shock absorber back in it's rightful place  Wink
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #84 on: 04 January, 2018, 10:06:12 PM »
Now on to the other side.
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #85 on: 04 February, 2018, 10:00:17 PM »
I finally finished fitting the 4 new shocks to the Delta today  Grin. So I thought I'd start him up & drive backwards & forwards to settle the suspension & check the camber angles. Unfortunately it was ticking over at 2000 RPM when cold then went up to 3000 as it warmed up! I'm guessing there's something wrong with the idle control valve? He hasn't been started up since October last year which probably hasn't helped  Undecided.
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
« Reply #86 on: 04 February, 2018, 10:44:00 PM »
Rob,
While your at it disconnect the hose to the throttle body and clean the butterfly  both sides and surrounds with carb cleaner, as you can get sticky petrol deposits here, and certainly wouldn't he a bad idea to clean the idle control  valve for the same reason.
Rob
« Reply #87 on: 07 February, 2018, 11:03:42 AM »
Thanks for the advice Brian, I gave those areas a good clean & the tick over is now back to normal  Wink.
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #88 on: 07 February, 2018, 11:14:15 AM »
I've been scanning some old photos today & came across this one. It's my old Beta coupe 1600 that I was halfway through restoring when I realised that my Delta needed restoring too  Undecided. Unfortunately I didn't have the time, money or space to restore both so after much thought I decided to sale the Beta  Cry. Still miss that car & wish I could have kept both.
« Last Edit: 20 February, 2018, 10:45:03 PM by Rob » Logged
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Rob
« Reply #89 on: 20 February, 2018, 10:43:48 PM »
I've been concentrating my efforts on the front of my Delta recently. I trial fitted the front wings & front bumper to see how it all lines up & with a bit of fettling it all looked pretty straight  Wink.
Rob MacFarlane
2000 Fiat Coupe 20v
1987 VW T25 Camper
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12   Go Up
Page created in 0.081 seconds with 20 queries.
