10 January, 2025, 04:13:13 AM *
Author Topic: Reverse brake bleeder  (Read 2261 times)
« on: 27 July, 2016, 09:48:56 AM »
Has anyone tried one of these? does it work on Fulvias!
TODAY's OFFER: (From Frosts)
V-5 DIY Reverse Brake and Clutch Bleeder
Never Have a Problem with Getting a Firm Brake or Clutch Pedal Again!
 Was: £45.00
NOW ONLY £37.99
The V5 DIY Brake Bleeding Kit has the bare necessities for world class brake and clutch bleeding at an economy price.
We have known for years that trapped air kills the response of even high end brake systems and leaves your "average" brake or clutch assembly mushy, weak and dangerous. So how do we obliterate trapped air making sure the brake system performs to its top potential?
By pushing the air up! Not Down...
Reverse Bleeding injects fluid at the low points, the slave bleeder valves. Reverse Bleeding takes advantage of the "laws of Physics" air rises in fluid. The complete system is bled by forcing the air up and out the master cylinder reservoir. The brake fluid then fills the reservoir.
FEATURES:
Patented reverse fluid Injection
Removes trapped air in brake system which is the main cause of a "spongy pedal"
Includes main fittings and adapters to perform basic brake and clutch bleeding
Suitable for all brake fluid
Easily bleed ABS
Good for DOT 3, 4, 5.1
One man brake bleeder in 15 minute operation
Fits all vehicles - Great for Motorcycles
Multiple uses for the home and shop
No rebuild kits available
How to Reverse Bleed with V5 Brake Bleeding Kit
« Reply #1 on: 27 July, 2016, 06:54:16 PM »
Here is a video on it.
https://www.youtube.com/watch?v=uo2o3scqPUo
Presumably only the air moves not all the brake fluid which would overflow out of the master cylinder. However I can't see haw it would do that and also you don't replace with new fluid as you bleed.
Page created in 0.075 seconds with 20 queries.
