25 November, 2024, 12:38:38 PM *
Author Topic: Lower on one side.  (Read 7228 times)
Caracad
« on: 12 August, 2016, 09:01:26 PM »
Any idea why my Fulvia 3 would be riding higher on one side.
Have fitted new front Spring buffers, which has improved the ride quality but not levelled things out.
Could I have a broken rear leaf?
« Reply #1 on: 12 August, 2016, 09:12:47 PM »
Rear springs have gone soft and one in particular could be struggling to keep shape?? I had this and was cured by new set from Cav.
Caracad
« Reply #2 on: 13 August, 2016, 07:48:49 AM »
Okay thanks Tim,
Sounds expensive though.  Undecided
« Reply #3 on: 13 August, 2016, 10:30:44 AM »
Okay thanks Tim,
worth replacing the upper rear shackle mount at same time. Cav supplied the spring with silent blocks in when I bought my pair, which I didnt realise as I ordered these seperately. Anyway they got used on another car. Just worth checking....
Caracad
« Reply #4 on: 15 August, 2016, 09:35:21 AM »
Tim,
How did you rate the new springs. Omicron seem to think they are too stiff and so don't recommend them.  Undecided
« Reply #5 on: 15 August, 2016, 11:12:49 AM »
The Cav springs made in Italy with Italian steel I presume like original. I have no complaints. I have fitted front (S1 as lower) and back and the car is very supple but not soft. It goes round Goodwood every year (more or less) so you can draw your own conclusions.
Charles
« Reply #6 on: 15 August, 2016, 11:59:01 AM »
Just a thought Mark.  I had two new top leaves (the one with the silent block in) made for my Flaminia springs by a company in UK.  I sent them an old one (leaf i mean) and they copied it perfectly and it was not too expensive.  I can look out details if you think worthwhile. My Flaminia was low on one side and after much investigation it turned out that one of the silent block eyes had cracked and was allowing the top leaf to slide forward slightly thus lowering that side.  This was not visible without dismantling.
Caracad
« Reply #7 on: 15 August, 2016, 12:56:02 PM »
Charles I think your right, I should dismantle the springs to check them properly.
For one thing the uneven ride height happened quite suddenly. Car has been level, I think, until very recently.
Also there is a slight rattle from the rear suspension as I go over bumps.
Caracad
« Reply #8 on: 22 August, 2016, 12:45:41 PM »
Have stripped the springs down and not found an obvious problem. Both sides do seem very soft for a road springs, although ride height is high enough, just uneven.
Not sure what to do now, so will swap some leaves around, reassemble, and see if that evens things out a bit.
Read on here somewhere about replacing with composite springs. Now that would be cool, but don't think it got anywhere.
« Reply #9 on: 22 August, 2016, 03:08:51 PM »
I did this with mine and after assembly I could bounce up and down on them while they were inverted. I concluded they were too soft and ordered a pair from Cav which did not move under my considerable weight but were / are fine on the HF coupe now and for the past 10 years.
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #10 on: 23 August, 2016, 07:33:22 PM »
When you put your springs back together, swap them over from 1 side to the other and see if it sits lower on the other side, o/s  springs used to get weaker quicker due to always having someone driving the car, compared to the passenger side
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
rogerelias
« Reply #11 on: 23 August, 2016, 07:35:01 PM »
Oh and never overlook the obvious  tyre pressures. and the same profiles on both wheels, I HAVE seen it done  Cool
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
1968 MGC ROADSTER
« Reply #12 on: 24 August, 2016, 08:33:46 AM »
Is the front of the car sitting well?
Caracad
« Reply #13 on: 24 August, 2016, 10:59:30 AM »
Well initially I thought it was the front spring buffers, but I have replaced them, and it made no difference.
I assume it can't be the front spring as there is only one.
