John B
« on: 15 August, 2016, 03:54:37 PM » |
Since I have no chance of installing a hydraulic car lift (unlike certain lucky members ) and not wanting to dig through 2 metres of limestone bedrock to make a pit I have had to settle on a compromise ........ still, laying down to work has a certain appeal .
1961 Appia S3 1969 Fiat 850 Special
« Reply #1 on: 15 August, 2016, 10:59:56 PM » |
I just love that .... it looks sturdy enough!!!!
« Reply #2 on: 16 August, 2016, 12:04:30 AM » |
Someone in about 100 years time will no doubt wonder, what the heck were they used for Brian 8227
Jay
« Reply #3 on: 16 August, 2016, 09:12:37 AM » |
I can’t remember which European country/region, but I remember seeing concrete ramps similar, but bigger for HGV on the roadside of major roads. Do any other members recall seeing these ?
Julian Wood, Kingston, London
« Reply #4 on: 16 August, 2016, 09:14:12 AM » |
There used to be a set of ramps like this at Goodwood Circuit I recall which were very useful assuming you could get your car up there in the first place! The horizontal 'high' part was vehicle length which I found especially useful and I imagine they were demolished in the run up to the first Revival. Chris
John B
« Reply #5 on: 16 August, 2016, 10:28:11 AM » |
The thought had crossed my mind to extend the flat part......and even to continue with a slope down the other side.
« Reply #6 on: 16 August, 2016, 10:36:25 AM » |
Sounds like a bridge , I remember the ones at Goodwood they were pretty massive I expect they had been there a long time.
Neil 386
1973 Fulvia S2 1.3
« Reply #7 on: 16 August, 2016, 06:07:32 PM » |
I was working as an engineer on a bridge construction site in the early 70s, a time of significant industrial unrest!!!! All the major sites in Essex were shut down in one dispute and all work stopped, but as part of the Resident Engineer's staff I had to report for duty every day. My main task was to monitor movement of a bridge deck with varying temperature. Calculated expansion of the deck was 11 inches (280mm), the specification required the expansion joint to accommodate 16 inches (405mm) and the joint installed had a maximum capacity of 18 inches (455mm). Quite astonishing to monitor this level of movement in a bridge deck .... mind you, it was 2000 feet (600m) long!!! This task did not occupy the whole day!!!!
So my junior engineer and I fabricated a raised ramp using scaffolding and materials lying around on the site. Rather shaky and did not comply with any design or build regulations, even in those relatively relaxed times, but it did the job and allowed us to service and carry out repairs on our cars and indeed a couple of other engineers came down to join in the fun!! The RE turned a blind eye and the contractor was absent from site and so we got away with it.
Necessity is the mother of invention!!!
« Reply #8 on: 16 August, 2016, 07:06:51 PM » |
Goodwood (Nye). Why was it removed I wonder?
« Reply #9 on: 16 August, 2016, 07:18:15 PM » |
From 'Revs'
« Reply #10 on: 16 August, 2016, 10:11:29 PM » |
A thought crossed my mind having re-read this post and the mention of 'bridge' by Neil in the post that followed it. Construct the 'slope down the other side' as a mirror image to the ramps that you have already made and link the pairs of ramps with a pair of removable bridge sections. That way you have the rigidity of the fixed elements under the four wheels with the flexibility to remove the bridge sections to improve access for yourself, parts and tools etc. Weight might dictate the use of aluminium sections for the bridge elements. Also, for me in my forgetful advanced years, a warning system to ensure the bridges were in place before the vehicle could be moved would be helpful!!!!! Life's little challenges, where would we be without them? Andy
« Reply #11 on: 17 August, 2016, 10:47:18 AM » |
There are the remains of ramps like John's outside a disused garage in a neighbouring town. I must admit I wouldn't trust myself without help to stop in the right place. Maybe cement a couple of bricks at the end?
« Reply #12 on: 22 August, 2016, 07:04:07 PM » |
AstroTurf down the inside to lie on?
« Reply #13 on: 22 August, 2016, 08:11:57 PM » |
Luxury living eh David!!!!
John B
« Reply #14 on: 22 August, 2016, 09:02:16 PM » |
I've now made a crawling board (is that the correct term?) ...... 4 swivel castors, 1" thick plank and 3" of foam rubber. Probably fall asleep under the car now!
