26 November, 2024, 02:35:04 PM *
Pages: [1] 2   Go Down
Author Topic: Fuse box information  (Read 14635 times)
wildbunch
« on: 09 October, 2016, 07:52:36 PM »
Evening everyone.
Just been tinkering with my Lancia Fulvia MK2 1.6 HF earlier today and noticed the last fuse (far right) had blown, have tried several other fuses from 5 to 25 amp but they all blow when flicking the light switch. Does anyone have an idea what this one is for and indeed the others also has I don't have the fuse box cover and the manual is a little sketching to say the least. Also the blown fuse was black, what amp is this ?
Please see attached picture, you may notice several different coloured fuses so an idea of what amp fuse other people are using for each slot would be very helpful.
On another note are there any Fulvia owners in the West Yorkshire area ?
Stephen
1972 Lancia Fulvia HF1600 Lusso S2
« Reply #1 on: 09 October, 2016, 08:50:47 PM »
From memory Eight 16A fuses green usually fitted except 1x 30A (?) black, in position 8 counting from right to left in the fuse box there are some others held in line fuse holders too. Have you got a loose connection on light switch stalk, check the knurled ring is tight.
386
1973 Fulvia S2 1.3
« Reply #2 on: 10 October, 2016, 12:25:35 AM »
Neil,
I think the 16amp fuses is white, the handbook says 16a in all positions?
« Reply #3 on: 10 October, 2016, 10:35:02 AM »
The picture shows a fusebox and contacts that would definitely benefit from a systematic cleaning session. Check the connectors at the back of the fuses because they might give bad contacts and shorts. The fuses are all 16A, Andrea
« Reply #4 on: 10 October, 2016, 01:36:58 PM »
Definitely clean all contacts in the fuse box per fuse, I recently helped a HF owner rescue his car and one fuse with some corrosion made it run badly then not all, all my fuses are 16A, I have added extra relays and separate feeds and earths on the headlamps which makes some improvement.
386
1973 Fulvia S2 1.3
« Reply #5 on: 10 October, 2016, 06:06:26 PM »
Chugga who used to post here recommended putting a layer of solder onto all the fuse clips once clean to prevent them deteriorating again.
« Reply #6 on: 10 October, 2016, 07:05:28 PM »
How odd! A look at the fusebox on the Safari Stratos at Castle Combe a few weeks ago revealed that it's fusebox (same as a Fiat X19 1500) had a lot of silver solder on the contacts, some linking fuses together on the battery side.
wildbunch
« Reply #7 on: 10 October, 2016, 07:59:03 PM »
Evening,
Just like to thank everyone for the great advise and will be changing all the fuses this weekend to brand new 16a ones, have some which are red.
Will also be giving the fuse box a very good clean, any suggestions on a product I could use ?
Seems to be many different colour versions for each of the amp ratings, very strange. Nearly as strange has the multitude of differing amp and colours in my fuse box at the moment.
On another note I found a picture last night of the fuse box top with each fuses description, put it into a translator and made even less sense  Smiley..
Jaydub
« Reply #8 on: 10 October, 2016, 08:17:41 PM »
Hi Stephen,
According to my handbook it has 8 x 16A fuses and 1 x 30A. As previously stated, 16A fuses are normally Pink ( originally Yellow) but they can be Red or Green.  8A are white,Black or Blue. 30A are Red or Green normally. 25A are Blue or Grey. All very confusing so read the number on the body of the fuse.
Looking at your photo I`m assuming the blown fuse is number 1. Confirm by looking at the cable colours, White each side of the fuse. If so that feeds the side lights and maybe you have a short somewhere on the lighting circuit.
I think fuse number 9 has the 30A fuse as it feeds the Heated Rear Window and horn solenoid. Cigar lighter comes off of that also but has an inline fuse of its own.
If you want to know what the rest are I will post again tomorrow.
John
1600 HF. S2.
wildbunch
« Reply #9 on: 10 October, 2016, 08:38:34 PM »
Hi John,
Thank you for the great advise, and like you say its very confusing.
The fuse that keeps blowing is the far right one that's missing in the picture, (counting left to right number 9 on my rhd car) the rest are fine and going on what you have said it might be because it supplies the Heated rear window which isn't on my car as its Perspex. When I first noticed it had blow the fuse in there was black.
Would be great if you could let me know what the rest are tomorrow.
Thank you
Stephen
neil-yaj396
Committee
« Reply #10 on: 11 October, 2016, 06:18:26 AM »
Stephen
I have Beta Coupe rather than a Fulvia, but I'm in West Yorkshire (Bingley).
If your heated rear window has been removed there may be a bare wire that used to feed it going to earth. That will blow the fuse.
« Last Edit: 11 October, 2016, 06:23:19 AM by neil-yaj396 » Logged
nthomas1
« Reply #11 on: 11 October, 2016, 07:23:20 AM »
Interesting to read comments about the heated rear windscreen fuse.  My car (1973 Series 2 Coupe) does not have a heated rear screen but I know the screen was replaced by a former owner.  Can anybody tell me to which models the heated screen was fitted?  Was it fitted at all to the Series 2 - either as standard, or an option?  Or was it something brought in on Series 3?  Also, whereabouts did the wiring feed from the car to the screen?  I'd like to know because my electrics need some sorting out and I'd like to check whether I have a wire hanging loose somewhere that previously fed to the rear screen.
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
« Reply #12 on: 11 October, 2016, 08:24:47 AM »
I thought all S2 coupes and on had heater screens as standard.
386
1973 Fulvia S2 1.3
« Reply #13 on: 11 October, 2016, 09:10:33 AM »
My S2 never had a heated screen unless it had a replacement some time before I bought it. Although mine isn't a 1600HF so maybe it wasn't an option? A sticker with all the fuses marked in Italian and English can be had from Omicron (and probably a cover). I think so anyway - it's so long since I looked at mine, but I think I have both languages.
« Last Edit: 11 October, 2016, 09:19:14 AM by stanley sweet » Logged
Jaydub
« Reply #14 on: 11 October, 2016, 10:09:07 AM »
Hi Norm,
There are a lot more knowledgeable Fulvia owners than I, but according to the wiring diagrams and info that I have, the Heated rear screen was an option and is shown on the diagrams.
I cannot verify this physically but in my experience the wiring for the screen will go to the rear with the main loom ( left hand sill?). The switch is fed from fuse No.9 with a Brown wire, and from the switch a Red wire to a 4 way junction box and then to the screen. Fuse 9 is only live when the ignition is turned on and supplies a 6 way junction box ( instruments etc), ignition coil positive, pin 2 Horn relay and Pin 2 Radiator Fan relay.Also a Red wire feeds the oil Temp gauge from the rear screen switch.
Again, this only from wiring diagrams and may not be correct.
John.
1600 HF. S2.
Pages: [1] 2   Go Up
