21 December, 2024, 12:12:52 PM *
Author Topic: Support for Fulvia body after front subframe removal  (Read 7076 times)
Rosco
« on: 20 January, 2017, 12:02:57 PM »
Hello all,
I'm gearing up to drop my Zagato's front subframe, and want to build a frame (on castors) to support the body once it's lifted off. Are there any guides for dimensions, and where best to support?
Any help much appreciated,
Rosco
« Reply #1 on: 20 January, 2017, 02:45:35 PM »
Have you got the Fulvia workshop manual ?
Couple of photos from mine, there are more pages that cover the replacement of the subframe boxes if they need doing. However you coul make up a frame/jig using the original data
Rosco
« Reply #2 on: 20 January, 2017, 05:10:53 PM »
Thanks Simonandjuliet!
I've got all my bits for constructing it now, and with those diagrams I can crack on.
I don't have the Fulvia workshop manual, where can I source one?
Cheers,
Ross.
« Reply #3 on: 20 January, 2017, 05:44:45 PM »
Cheers,
Ross.
Re Manual you can buy them on ebay like this
http://www.ebay.co.uk/itm/Lancia-Fulvia-Factory-Workshop-Manual-Service-Technical-Instruction-/252726753590?hash=item3ad7b03936:g:gB0AAOSwLnBXVUE1
or you can buy the CD of much more from vivalancia .com
http://www.viva-lancia.com/specials/cd/fulvia-cd.php
Rosco
« Reply #4 on: 20 January, 2017, 09:51:24 PM »
Ta Lulu.
Ross.
Rosco
« Reply #5 on: 20 January, 2017, 10:57:31 PM »
Last question (ish) chaps,
I'm creating an H-frame on (lockable and swivelling) castors to attach to the two front and two rear subframe mounting points; this'll allow me to move the body around relatively easily, and get it on a trailer. How long are the mounting point bolts, and are they the same front and rear? I just want to ensure the frame is the correct thickness.
Ta,
Ross.
David32
« Reply #6 on: 21 January, 2017, 09:31:19 PM »
At present I have my series 2 front subframe out of the car. The front mounting bolts are 100mm long in the shank, the rears 110 mm.
Rosco
« Reply #7 on: 22 January, 2017, 05:46:13 PM »
Thank you, David.
Ross.
Jaydub
« Reply #8 on: 23 January, 2017, 11:16:01 AM »
Hi Simon
I have the Fulvia manual that Tim is describing on E-Bay but it doesn`t have the diagrams that you are showing. The chassis diagrams only date to 17/11/64 and yours show 1970? Also there is nothing about replacing the subframe boxes, in fact I cannot see anything relating to my 1600HF series 2 . I find the manual not a lot of use really. Am I missing something? The Tavola doesn`t show the boxes either, no part numbers or descriptions, just numbers that don`t relate to anything do they?
John
1600 HF. S2.
« Reply #9 on: 23 January, 2017, 12:05:03 PM »
Hi John
The workshop manual that I have is a very old version as produced by Peter Gerrish in 1977 (ish), with a fair number of additional typed pages. Is this now available on the CD version that Tim refers to ?
Sorry but I haven't a copy of the CD to compare
Jaydub
« Reply #10 on: 23 January, 2017, 01:55:18 PM »
Thanks for the reply Simon. I don`t know about the CD either.
1600 HF. S2.
« Reply #11 on: 23 January, 2017, 02:02:37 PM »
Hi John
No - if you look at the web address I gave you can see what you get - a lot!  I do not have a Peter Gerrish manual. Must see when next in the 'hood Simon.
