22 December, 2024, 06:10:52 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
S2 SZ Rear brakes
Pages: [
1
Go Down
« previous
next »
Author
Topic: S2 SZ Rear brakes (Read 2800 times)
kevbo
S2 SZ Rear brakes
on:
08 April, 2017, 11:24:02 AM »
My offside caliper is a little sticky & warming up the wheel. The handbrake is adjusted ok so I thought I'd ensure everything was correct with the caliper. I purchased from Omicron what I believe are the correct pad pins to replace the existing old split pin type.
The new pins use an R clip which goes through a hole in the pin just below the dome head of the pin. Any ways the upper pin went in easy enough but to insert the R clip the dome head has to be inboard i.e. Towards the centre of the car. However the lower one won't go in the same way, the rear spring getting in the way. The pin will go in the other way, but the hole is obscured, the caliper body being slightly too wide around the outboard hole.
I must be doing something daft? Any thoughts?
kevbo
Re: S2 SZ Rear brakes
Reply #1 on:
10 April, 2017, 05:10:07 AM »
Ended up pretty much losing my brake pedal after going for a long run and just after applying the brakes relatively firmly a few times. No loss of fluid, so assume I've boiled the fluid? Pumping the pedal got some brake performance back. Looking back at my posts the rear brakes have previously been a problem, maybe the best way to go is replacement caliper? .
Regards
Kevin
Reply #2 on:
10 April, 2017, 05:35:05 AM »
You could rebuild it with a seals kit. Not too daunting if the pistons are not rusted. Even then you could get a set of replacement pistons.
1998 Zeta 21. 12v
kevbo
Reply #3 on:
10 April, 2017, 06:04:15 PM »
Thanks Tim, I did get a seals kit but started to wonder whether I'd be best to source refurbished calipers. Which ever way I go I need to get the calipers off so I guess it makes sense to see the state of the seals & pistons before shelling out £280 or so for a pair of refurbed calipers.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
