Author Topic: Appia Consortium News  (Read 107459 times)
lancianut666
  • Permanent resident
  • Slow but rough
Re: Appia Consortium News
« Reply #210 on: 21 August, 2024, 06:17:38 PM »
What was not obvious when I started was that the aluminium drum had a lip holding the cast iron liner in place along with the pegs, my theory was that if I bashed half of the lip off when the liner was cut in half one half could be tappe out and the other knocked out as it had room to move. One snag was when the liner was cut through it pinched the jigsaw blade and nearly pulled my arm off as the blade was stuck but the jigsaw still went up and down! I will have to decide if it is a good use of my time splitting the front drums up...watch this space.
Clarkey
lancianut666
  • Slow but rough
« Reply #211 on: 22 August, 2024, 06:18:47 PM »
Hi all
My mate Terry and I managed to refine the process to just one cut through the drum and liner and with a bit of levering the liner comes out in one piece...result! time spent down to about 15 minutes. Problem is we burnt out the jigsaw.
Clarkey
lancianut666
  • Slow but rough
« Reply #212 on: 11 September, 2024, 07:53:18 PM »
Well we are getting near to scrapping the unloved S2 so get in touch if you need any parts it has a good set of  four 15" wheels, a working engine and gearbox, front seats, doors, bonnet, boot, grill, wiring loom, horn, bonnet and boot catches, petrol tank etc.
Clarkey
Spider2
  • Megaposter
« Reply #213 on: 12 September, 2024, 01:34:38 PM »
Hi,
I need:
1/ Horn
2/ x 1 Headlamp chrome surround
3/ Interier roof lamp assembly
4/ Heater valve and cable
5/ Speedo cable
6/ Side panels (by drivers and passengers knees)
6/ Possibly wiring loom.
I have finished phase 1 of the recommisioning so the car is safe and driveable. Phase 2 will be the nice to do items so I am sure I will need a lot more in due course. Will all the bits be kept in storage?
Simon
lancianut666
  • Slow but rough
« Reply #214 on: 13 September, 2024, 01:50:37 PM »
Hi Simon
All the parts are in storage now I just have to take the front axle off. I will check what we have on your list and get in touch. see pictures
Clarkey
lancianut666
  • Slow but rough
« Reply #215 on: 16 September, 2024, 09:45:04 PM »
Hi all
The S2 is stripped now with the following parts available
engine
gearbox
front seat
steering column
steering wheel
front doors in aluminium
boot
bonnet in aluminium
grill
wiring loom
plus many others so get in touch.
Clarkey
lancianut666
  • Slow but rough
« Reply #216 on: 17 September, 2024, 05:20:42 PM »
Said goodbye to the S2 today...it seems the bottom has fell out of the scrap market as 3 metal recyclers were going to charge me to come and pick up the shell! anyway my local scrapman came and took the lot FOC so saved a lot of hassle. He wasn't too impressed that he could pick up one corner of the shell single handed.
Clarkey
lancianut666
  • Slow but rough
« Reply #217 on: 25 November, 2024, 07:29:45 PM »
Hi all
Amongst a lot of things picked up from the late Don Cross's estate was a small rather heavy bag containing ' a thing to trim your brake shoes with' so here it is in all it's electro/mechanical glory. The question is has any one ever used it and was it of any use?
Clarkey
ps I feel sure there must be some instructions somewhere but I have not come across them yet.
lancianut666
  • Slow but rough
« Reply #218 on: 25 November, 2024, 07:36:13 PM »
some pictures
lancianut666
  • Slow but rough
« Reply #219 on: 25 November, 2024, 07:40:24 PM »
Attached to the plate were four large nuts that I assume act as spacers and would fit behind the circular plate that would be fastened on with wheel nuts. There were several grinding bits of different diameters so presumably you can take off enough to get the thickness of lining you require.
GerardJPC
  • Megaposter
« Reply #220 on: 01 December, 2024, 07:01:47 AM »
Thanks for these great updates, Jim!
lancianut666
  • Slow but rough
« Reply #221 on: 21 December, 2024, 10:21:17 PM »
Some good news for a member with severe engine difficulties as he has reported the engine from Don Cross' estate is installed and going well.
will
  • Senior Member
« Reply #222 on: 07 January, 2025, 11:24:01 AM »
Lancia produced a tool for trimming the front brake shoes on all the sliding pillar cars
I visited garage in Turin many years ago  where they had the adaptors for each model
it was was mounted on the stub axle and it had cutter to trim the shoes which you turned by hand
around the brake shoes so they fit the brake drum better and improves breaking .
My guess is Don's tool would do the job just as well
lancianut666
  • Slow but rough
« Reply #223 on: 09 February, 2025, 12:50:36 PM »
I must confess I am tempted to try this on some none asbestos shoes. I assume the ones on my car relined a few years ago will be in this category as I had to sand a lot off them to get the drums on so I think it will be a worthwhile exercise.
Clarkey
lancianut666
  • Slow but rough
« Reply #224 on: 09 February, 2025, 12:56:51 PM »
Hi to all Appia Consortium members past and present...you've guessed it I am on the look out for some articles for the newsletter as I will be getting the printing presses rolling over the next few weeks. In addition I will be sending out the renewal forms for membership. I have already received a renewal payment from our Scandinavian outpost well done Daryl!
Clarkey
ps as an aside I had a request from a member for a window winder handle as he had checked if the ones on his Appia would fit his Augusta...they do...result
