26 November, 2024, 04:33:20 AM *
Pages: [1] 2   Go Down
Author Topic: Rear suspension, subframe and engine removal  (Read 14972 times)
nthomas1
« on: 07 May, 2017, 06:37:35 PM »
I’m progressing slowly with my S2 Coupe rebuild, and plan a concerted effort when I get back to the UK at the end of this month to get the bodywork completed and the car painted.
So far, my strategy has been to keep the car as a rolling shell with engine still installed.  That’s how it is now.  All interior and exterior trim has been removed as has the glass and closures (bonnet, boot lid and doors).
I’m now wondering whether to remove the rear suspension and the front subframe and engine.
The pros of doing this are: (1) the painting of the car could go ahead unencumbered by the installed mechanicals, (2) it would enable me to disassemble the suspension and chassis components and refurbish them, and (3) access to the rear springs and shock absorbers would allow me to correct the abnormally high ride height of the rear of the car.
The cons are: (1) I’ve never done anything on this scale before, (2) recent forum threads about difficulty of removing hub nuts has made me very nervous about the undertaking, and (3) I would have to invest in some form of support for the car, so that it can still be moved around, and can be transported for painting.
I have read up extensively on refurbishing approaches and techniques and have studied the forum threads and those of other Lancia communities in detail - and have built up a large library of information and reference photographs.  However, there’s no substitute for hands-on experience.  As a late starter to car mechanicals and electrics, I’ve have already achieved a lot more than I ever expected to in getting the car to this stage.  Jobs like glass removal, bodywork repair and dashboard renovation have been tackled with (in my opinion, and by my own standards) quite a degree of success, despite a garage with no power, and only rechargeable tools at my disposal.  I’m fortunate to have built up a lot of general do-it-yourself expertise over the years and this has put me in good stead for the rebuild work.
So, the question is do I proceed with the rear suspension, subframe and engine removal?   If I do, would it make sense to keep the engine installed in the (rolling) subframe - even though this would limit access to the subframe for refurbishment?   Any thoughts on where I’d encounter the biggest problems, and what special tools I’d need?  And is there any advice on how best to support a non-rolling body shell…… is it possible to hire mobile supports or would I have to buy them (but hopefully be able to sell them after the project is complete)?
« Last Edit: 10 May, 2017, 07:29:04 AM by nthomas1 » Logged
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
andyps
« Reply #1 on: 07 May, 2017, 08:33:17 PM »
I don't know particularly about the removal of things you have discussed but in terms of supporting the car and making it mobile without my suggestion would be to make up a frame to stand it on. One way to do that would be based on a bread trolley if you can get hold of one - they are surprisingly strong! Alternatively, and probably better, would be to use suitable steel tubing or angle iron to make a bespoke frame and mount it on castors so you can move it in any direction - I noticed Aldi had some large castors this week for £10 each, didn't check the load rating but they certainly looked strong.
nistri
« Reply #2 on: 08 May, 2017, 12:56:30 PM »
"to correct the abnormally high ride height of the rear of the car." Without measuring the actual height it is difficult to say if it is abnormally high. Most cars suffer from definitely low height at the back because of weak springs. The height should be checked with the spare wheel in the boot, tools and petrol in the tank. Of course, also standard wheels and tyres. If it is a bit higher than expected (good springs), it should settle after driving the car for, say, 1-2 K miles.
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
nthomas1
« Reply #3 on: 08 May, 2017, 03:46:58 PM »
Thanks Andy.  I was wondering about something like that.  I've seen quite a few contraptions on the various forums that other people have constructed.
Norm Thomas
Own:
nthomas1
« Reply #4 on: 08 May, 2017, 03:52:11 PM »
Thanks Andrea.  I measured the height of the wheel arch tops on my car before I started the rebuild, and I measured four Fulvias at the AGM last year.  My car sits 5cm higher at the back and 4cm higher at the front than the average of those four cars.  The owner before me did some classic tours and had fitted a roll cage and tripmeter etc, so I wondered if he had raised the suspension.  Would I be right in thinking that the ride height is a function of the spring stiffness and the shock absorbers used?  Is there any other way that ride height may have been increased - for example by using spacers of some sort?
Norm Thomas
Own:
nthomas1
« Reply #5 on: 08 May, 2017, 05:15:47 PM »
Here's one of three rolling frames I found on the various forum threads.  I found a similar one made of wood.
Norm Thomas
Own:
« Reply #6 on: 08 May, 2017, 05:46:56 PM »
Nothing to do with shock absorbers..... Lower front generally is down to the spring to top-wishbone rubber bobbins going soft / collapsing (in part/full), or less likely the spring itself has weakened. I know that when this happens the car is dramatically lower and generally riding around on the bump stops (Series 2) - (Series 1 coupe has a flatter spring to begin with....). Rear ride height can be down to the spring "riding up". When fitting the rear springs there are a number of silent blocks (upper and lower rear shackles, lateral stabiliser bar and shock absorbers). All these need to be tightened with the rear suspension in compression (the manual gives the settings). So you can see if this has not been done correctly then the rear will be higher. Equally if the rear shackles are loose or  the silent blocks worn out then the spring will be higher. Yes you can use spacers to raise the front or rear but this is most unusual (v rare).
nthomas1
« Reply #7 on: 08 May, 2017, 08:22:15 PM »
Thanks Tim - that may well explain the extra height at the rear.  Can a similar reason explain the front being too high?
Norm Thomas
Own:
nistri
« Reply #8 on: 09 May, 2017, 05:59:41 AM »
"I measured four Fulvias at the AGM last year.  My car sits 5 cm higher at the back and 4cm higher at the front than the average of those four cars. " Are you sure their height was correct Cheesy?
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
nthomas1
« Reply #9 on: 09 May, 2017, 08:18:06 AM »
Good point Andrea.  Is there any way of finding the factory measurements for an S2?
Norm Thomas
Own:
« Reply #10 on: 09 May, 2017, 08:25:03 AM »
nope. If the spring has been changed for a aftermarket remanufacture then the steel and tempering could create a stronger spring with consequential ride height increase. But this is very uncommon. Also if the spring clamping in the centre is not correct(or broken in some way) then the spring could move a bit. But you would hear this driving. Also always measure a fulvia on horizontal ground......
nthomas1
« Reply #11 on: 09 May, 2017, 08:36:25 AM »
Interestingly, in the S2 sales brochure the car in the photograph looks like it has similar gaps between tyre and wheel arch top at the front and rear, whereas the diagram underneath appears to show the car with a nose-up attitude.  I was hoping I could find a factory picture that would allow me to measure the ratio between tyre diameter and the gap between top of tyre and top of wheel arch!
Norm Thomas
Own:
stanley sweet
« Reply #12 on: 09 May, 2017, 10:49:51 AM »
That brochure shot is strange. I've never seen a Fulvia sitting that level unless it's been lowered slightly for track use. Most Fulvias have a nose down attitude. Here's a photo of mine. The suspension has never been touched since I've had it and as you can see it sits higher at the back. It's exaggerated slightly by having lower profile tyres so it wouldn't be any good me giving you any measurements.
« Reply #13 on: 09 May, 2017, 11:00:25 AM »
Fulvias do have a positive rake. S1 is less pronounced and as already discussed has different front and back springs. A lot depends on full tank (& dead body etc in the boot).....
the.cern
« Reply #14 on: 09 May, 2017, 07:59:58 PM »
Hello Norm, I cannot help with ride heights etc, but a couple of points re a dolly or similar to keep the shell mobile. In my experience it is always worthwhile using steel/iron rimmed castors, this minimises rolling resistance. It is amazing how nylon or runner rims can distort and make moving the shell so much more difficult. The second point is to always have two, if not all four of the castors lockable. Then, when you want to really lean on a tool, the shell will not just run away from you!!! These points are made from bitter experience!!!!
Good luck with it all,
                                Andy
Pages: [1] 2   Go Up
Page created in 0.071 seconds with 21 queries.
