25 November, 2024, 07:33:27 AM *
Pages: 1 ... 18 19 20 21 22 [23] 24 25 26 27 28 ... 51   Go Down
Author Topic: Report on (slow) S2 Coupe rebuild progress  (Read 273658 times)
0 Members and 119 Guests are viewing this topic.
Jaydub
« Reply #330 on: 24 April, 2020, 09:43:35 AM »
Hi Norm, 3 pin flasher units earth through the fixing bolt onto the chassis. `P` is used for a warning lamp, and as the warning lamps 44 & 49 are fed from connector blocks 37 & 42 and earthed through the black wire on connector block 37, it is not used.  On the models with Hazard Flashers, the same 3 pin flasher unit is used but instead of the Red wire ( 12 volt feed) it has a Yellow wire which is the 12 volt feed from the Hazard Switch. ( 46 on the other diagram).
The Ford unit looks like Hazard unit because it appears to be 98 watt which is used handle the current from 4 x 21 watt flasher bulbs + 2 x 6 watt repeater lamps totalling 96 watts. As you say though, it may just be replacing the faulty OEM unit.
Hope that helps.
John
1600 HF. S2.
nthomas1
« Reply #331 on: 24 April, 2020, 06:53:50 PM »
Thanks John - that's a huge help, and good to be talking in terms of wiring diagram reference numbers that I can recognise.
I traced the red wire from the flasher and on my car it goes directly to the Connection Block 42.  The wiring diagram for 64, however, shows the red wire leading to 53, which is another flasher (handbrake and brake fluid low level warning), and then to 42.  Any idea why the difference?
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
Jaydub
« Reply #332 on: 25 April, 2020, 09:48:32 AM »
Norm, the red wires are  12 volt feed  from the Ignition switch (55) , Blue/Black wire, to fuse No. 9 and through the fuse to terminal block 42, which supplies the Instruments and flasher 53 and 64. The order is not important as long as they are all connected and supplied with 12 volts.
  Try to think of the Red wire as a continuous wire from the Fuse box but supplying different components on the route. As a point of interest, when doing continuity checks to trace wire sources and destinations, every component has to disconnected or else you will get a false reading through a component connected to the same source, if that makes sense.
John
1600 HF. S2.
nthomas1
« Reply #333 on: 25 April, 2020, 06:38:53 PM »
John - that's great.  With your help I think I'm getting there.
Now I understand the way the power flows from the ignition switch through the fuse, and to the flashers in series.  I've also traced the blue/black and blue wires from the direction indicators at the corners of the car via 37 and 42 (for the indicator warning lights) to junction block 59, and thence to the stalk on the steering column.
Am I right to assume that within the stylised steering column assembly symbol there's a link (not shown) from the white wire coming in from 64 to the blue and blue/black wires that are shown near the indicator stalk?
If my understanding above is correct that is the flasher sorted.  However, for 64 to also control hazard flashing wouldn't there need to be some linkage somewhere to a separate controlling switch on the dashboard?
Norm Thomas
Own:
Jaydub
« Reply #334 on: 26 April, 2020, 01:41:01 PM »
Norm the White wire is connected to either of those two wires by the Flasher switch internal contacts.
To operate Hazards you need to refer to the other Coupe diagram, (46) Hazards Switch and (39) Hazard Flasher unit. So you need both of those plus extra cable to connect them all. Hand brake flasher (62) normally supplies the Haz/switch pin 58 and simultaneously normal Flasher unit (63). When Hazard switch operated the supply to its pin 56 comes from the Headlamp solenoid (37) which in turn supplies the Hazard Flasher unit (39) via pin 57 which then operates the W/Lamp on pin 30b of Haz/switch.
John
1600 HF. S2.
nthomas1
« Reply #335 on: 27 April, 2020, 07:34:26 PM »
Thanks John.  For the moment, and to keep things simple, I'll stay with the basic flasher functionality.
Norm Thomas
Own:
nthomas1
« Reply #336 on: 27 April, 2020, 07:35:47 PM »
I could do with some help on connectors.
The first picture below shows connections for my left rear light cluster.  I’ve checked against the wiring diagram and all seems correct.   The right rear cluster, however, has been connected without the use of a junction block - see second picture.  Three of the connectors are crimped-on insulated, and the fourth is a bullet type connector.  I have a spare 4-way junction block (picture 3) so would like to re-do the connections to match the left side.   The junction block that I have has got correct Fulvia connectors in it, and I’ve figured out how to release the male spade connectors by pushing in the locking clip with a small screwdriver.  I can’t see how to remove the female connectors though.  Is there some trick to this?
My next question is where to buy the correct type of connector.  I can’t seem to find them on-line, and I’m not sure what spec to be looking for.  I bought some 6mm wide ones but they seem much lighter gauge - silver finish, and maybe 0.4mm thick rathe than the approximately 0.7mm of the original gold coloured connectors, and they don’t have the locking fixture. See picture 5.  I assume that using the correct thickness is important.   Also, these are the type without integrated insulation covers so they can’t be crimped with my crimping tool, (picture 4), which seems to be only suitable for insulation-on connectors.
Should I forget the junction block approach and standardise on male to female connectors of the insulation-on variety?
Any pointers would be appreciated.
Norm Thomas
Own:
« Reply #337 on: 27 April, 2020, 08:43:20 PM »
Nooooo! Get back to the original connector blocks Norm!! It will allow you to disconnect them easily and reconnect without having to go back to the wiring diagram. Disconnecting the female connector from the block (picture 3) requires a jewellers screwdriver pushed into the slot in the mating face whilst holding the block between your thumb and forefinger and pulling on the cable gently. The preinsulated type connectors need binning. Total botch job!
You can get the connector blocks, male and female terminals from Vehicle Wiring Products. They'll also sell you a decent crimp tool!
https://www.vehiclewiringproducts.co.uk
« Reply #338 on: 27 April, 2020, 08:56:47 PM »
Decent crimp tool. Yell if you want to borrow one.
https://www.vehiclewiringproducts.co.uk/c-1-home/c-51-crimp-tools/c-119-non-insulated-terminal-crimping-tools/p-269-ratchet-crimping-tool
Female terminals with locking tab
https://www.vehiclewiringproducts.co.uk/p-429-female-blade-with-latch?search=female%20blade
Male terminal with locking tab
https://www.vehiclewiringproducts.co.uk/p-430-male-blade-with-latch?search=male%20blade
Both suitable for the connector block you have.
https://www.vehiclewiringproducts.co.uk/index.php?route=product/search&search=multi%20connectors if you need more!
Heatshrink to completely over the top insulating stuff!
https://www.vehiclewiringproducts.co.uk/p-606-adhesive-lined-polyolefin-heat-shrink-sleeving?search=heat%20shrink&page=2
And solder just to make sure the connection is perfect!
https://www.vehiclewiringproducts.co.uk/p-941-multicore-solder?search=solder
nthomas1
« Reply #339 on: 27 April, 2020, 09:37:54 PM »
Brilliant - thanks Guy.  I've ordered a batch of the male and female terminals, some ring terminals and some extra blocks.  I'll take you up on the loan of the crimping tool if you're sure that's ok.  I'll call by this week.
Norm Thomas
Own:
« Reply #340 on: 27 April, 2020, 10:07:45 PM »
No worries Norm - I'll dig out a relay holder too! See you soon. I'm working from home this week so just give me a call anytime!
nthomas1
« Reply #341 on: 01 May, 2020, 06:31:55 PM »
I’ve fitted the radiator.  In fact I fitted it twice.  Got it installed and connected up all the hoses and then realised I’d not fitted the two M5 captive nuts that take two of the three screws that hold the fan.  Tried installing them with the radiator in situ but impossible! So out it came, captive nuts fitted, and back in again.
I installed the two horns, and connected most of the mid-engine-bay wiring to the starter motor, alternator and various ancillaries.
I’ve tracked all the wiring down the passenger side of the engine bay, largely lighting related, and checked everything against the wiring diagram.  Mostly straightforward, but I need to understand the deviations from the wiring diagram caused by the car being RHD with UK headlamp configuration.
The driver side of the engine bay is more complicated, with a bunch of relays and other devices - see third picture to sort out.  I’ve worked out from the wiring diagram that the central black device is the voltage regulator, with all 3 wires going to the alternator.  I’ll need to trace the other wires to work out what the other devices are: some sort of relays/solenoids I assume, with more of what looks like non-standard additions, especially the one with the blade fuse!.
Lots of dodgy looking connections, but I’ve bought connectors and junction blocks from Wiring Products, the company recommended by John and Guy.  They’re service is impressive, with very fast delivery.  They made up a couple of correct length battery cables for me as well.
So, armed with the crimping tool kindly loaned by Guy, I’ll start making all the engine bay connections good tomorrow, and continue with the detective work.
« Last Edit: 01 May, 2020, 08:35:14 PM by nthomas1 » Logged
Norm Thomas
Own:
« Reply #342 on: 02 May, 2020, 06:46:32 AM »
The voltage regulator is an aftermarket item, difficult to say if it is an electronic type (probably yes). Advisable to carry a spare one when planning a long trip. Andrea
nthomas1
« Reply #343 on: 02 May, 2020, 07:09:12 AM »
Thanks Andrea. I thought it was original as it's exactly the same as one on another owner's car - see photo.  Is that just a coincidence then?
What would be the symptoms of a voltage regulator failing, would the battery stop charging?
Any idea what the other 3 devices are? From the TAV picture it looks like 2 of them may be solenoid switches for radiator fan and main beams and horns.
« Last Edit: 02 May, 2020, 07:36:45 AM by nthomas1 » Logged
Norm Thomas
Own:
« Reply #344 on: 02 May, 2020, 10:17:30 AM »
The battery may stop charging due to a number of things.
1. Alternator diode pack defective
2. Alternator brushes  worn
3. Alternator commutator dirty/worn
4. Regulator faulty
5. Fan belt loose!
Have you had your alternator checked over?
Pages: 1 ... 18 19 20 21 22 [23] 24 25 26 27 28 ... 51   Go Up
