27 November, 2024, 12:26:40 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Fulvia series 1 tyres and heater
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Fulvia series 1 tyres and heater (Read 9415 times)
Re: Fulvia series 1 tyres and heater
Reply #15 on:
12 October, 2017, 03:35:16 PM »
Maybe the standard temperature 2c, can you fit second series coupe matrix?
386
1973 Fulvia S2 1.3
Caracad
Reply #16 on:
12 October, 2017, 08:58:49 PM »
No idea why my heater should work so well.
It uses a simple water valve and also two flaps in the heater box that direct either all or some of the air through the matrix. I guess the flaps give a but more control.
I suppose if the flaps aren't adjusted right this would reduce the amount of heat.
I do know the S2 & 3 heaters are better than on S1 cars.
Last winter I never needed to have the heater on full. Also it heats up really quickly from cold.
Reply #17 on:
12 October, 2017, 11:35:07 PM »
Quote from: lancialulu on 12 October, 2017, 02:58:33 PM
Quote from: Justin McArdle on 12 October, 2017, 12:38:52 PM
Tim, as the other member of the highly exclusive 2C Club, I would stress neither I or Brian own a fur coat ! We do share equally inefficient heaters though!!
2C = Too cold???
No, no problems on that score.
8227
winter
Reply #18 on:
25 October, 2017, 11:36:53 AM »
Refurbmishment of my 1600 HF just complete. Fitted Toyo Proxes 185/65/14 to cleaned up wheels. Seem to work very well and don't look too modern.
Have replaced heater valve but still runs hot all the time.
roddy
Reply #19 on:
29 October, 2017, 01:21:06 PM »
Here is an explanation of the controls of a Series 1 Fulvia heater, which may (or may not) answer some of the questions :-
The blue knob wheel is connected to a flap on a vent in the scuttle and controls the amount of air entering the heater system. Fully clockwise, the vent is closed and no air enters the heater. Anti-clockwise the vent is fully open for maximum air.
The red knob wheel is connected to a flap over the leading face of the heater matrix. Fully clockwise, the flap is against the heater matrix and prevents any air going through the (hot) core (if the water valve is open). It is really an air temperature balance control.
The short lever works the water valve - forward: closed; back: hot water valve open. Touching the hoses would show if the temperature is the same on either side of the valve and on either side of the heater core.
The long lever obviously directs the air to the screen/vents or footwell.
As a radiator core can silt up in certain circumstances, similarly so can the heater core.
A final important point is to remember that the Series 1 system is designed to use a .25 bar radiator cap. If you use a higher pressure cap, viz: Series 2 .5 bar, there is just a risk that the heater core may perforate.
Regards -
Roddy Young
Dunfermline, Fife
1970 Fulvia Sport S1 1.3S
GG
Reply #20 on:
29 October, 2017, 07:59:52 PM »
Many years ago (when the cars were a bit fresher) we used to check two things for heat:
First, we'd check if the engine water was hot enough. We'd put a big piece of cardboard in front of the radiator to raise the water temp. Never got too hot. Still do that today on other Lancias.
And second, we'd check the rubber diaphragm at the heater valve. They sometimes need replacing, as they would swell up and constrict water flow.
Probably, by now, the heater cores might need cleaning out, as noted above.
Pages:
1
2
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
