I am being lazy here Neil for which I apologise in advance......but ref the festoon bulbs you fitted what length does your Fulvia use? And do you happen to know the length of the festoon bulb which sits above the fuse box in a S1 sedan?
I presume the LED bulbs run cooler and this would be beneficial because over time the fusebox cover distorts with the heat.
Finally which version of the BA9S bulbs did you fit?
Thanks in advance.
Chris,
I'm Confused, which bulb are you referring to? As I don't have a festoon bulb above my fuse box?
8227
