27 December, 2024, 01:20:21 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Augusta
Augusta fuel tank
Pages: [
1
Go Down
« previous
next »
Author
Topic: Augusta fuel tank (Read 3767 times)
Niels Jonassen
Augusta fuel tank
on:
26 April, 2020, 12:31:29 PM »
A friend has asked me if I know anyone who can help him with a fuel tank. The tank in his Belna is leaking through a number of rust holes in the bottom. I have suggested that he has a new tank made, but it will of course be much easier if there is a tank available somewhere.
Kari
Re: Augusta fuel tank
Reply #1 on:
08 May, 2020, 08:22:31 AM »
I suggest to open the tank at the bottom and go from there. My tank had a repair many decades ago but was still rusting inside. I have removed the repair sheet and cleaned the inside. Soldered pin holes at the bottom of the float tube.
Not so easy to make a new tank. Float tube, baffles etc.
Regards Karl
Reply #2 on:
08 May, 2020, 08:03:21 PM »
Am trying to puzzle it out.
Is it closed with rivets then soldered to seal?
Kari
Reply #3 on:
09 May, 2020, 09:03:54 AM »
The petrol tank had a repair probably in the late 1940's. The angled sheet on the left is a repair sheet which was riveted to the bottom and the rear of the tank and sealed by soft solder. About 15 years ago I had an annoying leak at a baffle attachment rivet at the front of the tank. But only whe I opened up the tank, the mess came visible. I then removed more corroded metal, cleaned the inside and riveted the whole lot together with copper pop rivets, which I got from the local plumber. Sealing was done again by soft-soldering. While the tank was open I have removed the fine mesh above the petrol outlet, which collected much dirt and restricted the flow of petrol. Instead of, I use a fine mesh on top of the glas bowl.
A spot to watch is the bottom of the float tube. There, water from condensation can pool and cause corrosion. When the tank is installed in the car, the repair is not visible.
I think the corrosion started when the car was standing in a damp place during war time without any petrol in the tank. Condensation then led to the damage.
Regards Karl
Reply #4 on:
09 May, 2020, 09:50:24 PM »
Just looked up copper pop rivets. New to me. Says used for roofing and gutters etc.
Kari
Reply #5 on:
10 May, 2020, 10:09:53 AM »
Exactly, for riveting gutters etc. Can be sealed by solder.
Karl
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
