« on: 28 January, 2015, 10:59:42 AM » |
In Glasgow.
Let me know if interested and I will forward email.
I am advised a best price secures.
« Last Edit: 28 January, 2015, 11:02:46 AM by lancialulu »
« Reply #1 on: 28 January, 2015, 03:29:35 PM » |
Curious what it is off, it is early type with exhaust ports at the back, but not off any Beta AFAIK (unless early Saloon)?
« Reply #2 on: 28 January, 2015, 03:53:02 PM » |
"AFAIK" - "as far as I know" ?? Not come across that before
« Reply #3 on: 28 January, 2015, 03:54:42 PM » |
The part number on the exhaust manifold cross references with Beta 1.3.....AFAGK (as far as Google Knows!)
« Reply #4 on: 28 January, 2015, 06:43:49 PM » |
Was the Beta 1.3 available with a cam mounted distributor? Thought they were all block mounted at the front with only the i.e. and VX having the dizzy there? Guy
« Reply #5 on: 28 January, 2015, 06:52:29 PM » |
Thats why I think it could be a Delta 1.3 but the exhaust number is confusing.
Sebastien
« Reply #6 on: 28 January, 2015, 07:06:19 PM » |
Delta 1.3 and Delta 1.5 were SOHC, not DOHC. DOHC came with the Delta 1.6 GT. Best use for that lump of (corroded) aluminium would be as a doorstopper (IMHO)
« Last Edit: 28 January, 2015, 07:09:02 PM by Sebastien »
« Reply #7 on: 28 January, 2015, 09:30:13 PM » |
It's not Beta, not with those engine mounts. None the wiser though! Carb ducting ought to give someone a clue?
« Reply #8 on: 28 January, 2015, 10:37:18 PM » |
Very Delta like then? An early 1.6??
« Reply #9 on: 28 January, 2015, 11:23:16 PM » |
"AFAIK" - "as far as I know" ?? Not come across that before Hi Simon Oops, sorry about that.... Must use full words Peter
« Reply #10 on: 28 January, 2015, 11:28:33 PM » |
What made me think it was maybe early Beta was what looks like a metal cover for the timing belt, the later Betas all had yellow plastic ones I think, but the engine mounts are definitely not Beta as mentioned, hence wondering if it was an early saloon, but I thought all of them had a similar mounting scheme.
So maybe the engine was transplanted into something else?
The answer is to get the number near the oil filter which would settle it.
« Reply #11 on: 29 January, 2015, 09:26:22 PM » |
Can't say I've ever seen that cambelt cover on a Delta? Brian 8227
« Reply #12 on: 29 January, 2015, 09:51:08 PM » |
Its seems not to be "Work In Progress" the way all the pipes have been cut. The cam covers do not have Delta recessed fastners. Could it be a Monte???
« Reply #13 on: 29 January, 2015, 10:23:55 PM » |
Not convinced the mount or the air filter is Monte. I guess we need the engine number...
« Reply #14 on: 30 January, 2015, 07:05:09 AM » |
The seller is not able to get more info. Based in Glasgow so if anyone wants to go look......
